I wanted to avoid Grinding the the rod journals down to 2.200" or any unnecessary machine work. I was wondering if anyone knew of any pistions that might work. I found a Ross piston that might work #99496. There was some minor differences in the rod length (.008") and in the stroke (.015"). I just dont know if this would create any interference issues in the piston skirt and counter weight area.
