Find an old used oem that still measures the right length and it will last forever.
I would be curious to know if the worn out ones were used with a high pressure pump or a standard pressure pump. Which end wears down? Cam end, pump end, both ends?
In theory, there is no difference between theory and practice. In practice, there is.
