I can see why that part is so pricey.. that started as a THICK piece... very nice
Thanks,
Yep, 1-1/2" thick. Needed that much to be able to enclose the timing belt. It's pocket milled front and back. SW shows about 20 lbs. I'm good with that for an accessory drive bracket/motor mounts/and water pump back plate/timing belt cover.
