The WV code says you can register them but the plates have to be inspected and approved. Now here is where it gets a little weird. A vehicle with antique plates can only be used for parades, events, on weekends and for transportation to and from said events or for repairs and road tests, these vehicles don't require an annual inspection. However if you are using vintage plates of the year of manufacture you can use the vehicle for general transportation but the vehicle has to be inspected and you have to pay the regular vehicle registration price.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost conversion. 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
