Originally Posted by AndyF
[quote=A/MP]Anyone modify the factory timing chain cover to eliminate the water pump? Instead of redoing the rad support, I thought about installing a 3 row rad in my early A and use a remote water pump with either -AN or barb type connectors. Fill in the cooling ports on the timing cover with the fittings and match the lines with the new rad. Simpler way?
Something like this?
I thought that I saw something like that with a Jessel belt drive. Thought it was a Jessel products.
