Originally Posted by lewtot184
if I had to have 500hp from a 383 i'd pro-charge it. 500hp from a 383 with big cams, FI, big crank, big heads, etc just sounds miserable to me. a real 360hp-380hp for a pump gas driver would be fun; done this before. a warmed up pump gas/license plate, reliable, easy maintenance 400-420hp 431 would be more fun. blowing a bunch of money for the more exotic build and just plain enjoyable fun aren't always on the same page. low gears and loose torque converters are miserable. another thing; can you tune the more radical build? how dip can the money pit be dug before you begin to regret it?
I can make nearly 750hp on a stroked 383/496 for less than the price of the Procharger!
and then the next guy says he can make 1000hp; to what end? worthless money pit?
My point was you do not need a procharger . The 383 is very capable of attaining the goal without it...Prochargers are neither cheap or nor super easy to tune....
'70 Cuda,...605 EFI Hemi Street Car (6.20 best pass, 1.33 60ft)
https://www.youtube.com/watch?v=WYw6RA-k5Bk (6.25 at 108.75mph from inside car)
https://www.youtube.com/watch?v=3zQEb9uxFng (6.25 at 108mph from outside car)
'66 Barracuda AWB Stretched nose Blown 440 Car in build stage
'71 Duster Drag Car 400 Low Deck 512 best 6.002 at 115.44mph
https://www.youtube.com/watch?v=Znuo3jMUXTk
