Guys!
Ok, so I'm using a older Holley Street Avenger 80670, and for the most part it works fine (as long as I start it and run it every day, or every other day).
However, recently I've noticed that if I let the car sit for more than 5 days, the accelerator pump stops working.
I think that I know what the problem is, although I don't know of a solution.
For whatever reason, the fuel in the carb metering block seems to solidify (for lack of a better term) and prevents any gas from being expelled out of the discharge nozzles, (a.k.a, squirters).
I've had this problem several times in the past, and I've had to use compressed air to clean out the orifices.
Any suggestions?
