Thanks 68.
I sent the shocks to Ron Galbreath at Afterworks, they should arrive at his shop today. He's going to put them on the dyno to evaluate them and let me know what he finds, then go from there. He said that Vikings are good shocks with good parts but they don't get the love (his term) when being assembled as higher end shocks.
Yesterday I put the front tires back on so the car would done when the shocks come back. For some reason I grabbed one of the tires and turned it. When it started moving there was a bump, so I stopped and turned it back the other way, same bump. Turns out my idler arm is bad on the k member end the end on the drag link would move up or down almost 1/2". I used all Moog parts when I rebuilt the front end years ago, it probably has 8-10,000 miles on it since.
