With the mild gearing, you should be able to spend enough time in each of the lower gears to be able to determine if/where it’s starting to lay down...... or if it will easily rev high enough to reach or exceed the optimal shift point.
I find 2nd gear is usually the easiest for me to tell when it’s either flattening out, or nosing over.
68 Satellite, 383 with stock 906’s, 3550lbs, 11.18@123 Dealer for Comp Cams/Indy Heads
