Saw the sheet on facebook..Congrats on the new best, sounds like the changes and weight coming out showed a big improvement
Al, weight is perfect now. Every time I went over the scales it was 3055, im supposed to be 3050.
I have the air too low in the tires, and watching the vids I see now that when it spins it shakes the tire first. Its getting really wrinkled up and when the wrinkles hit the bottom of the tire...there it goes, spins . So my plan is add some air, and maybe tighten the ext on the rear shock.
There some other things in the progressive that really helped the 60' come around
