I have a Ryobi inflator and like it. It was relatively cheap because I already had several Ryobi batteries.
The built it gauge is not at all accurate but does seem to be repeatable. For example if you shooting for 12lbs you may need to fill it to 18 on the pump's gauge before you check it with a real gauge. However for the next tire you can do the same and get the same results.
