I used arms off an 85 Ford pickup on mine. Had to tweak them just a bit to sit level in park but they fit and work. Bonus is they are J hook style so a modern 18" blade works just fine. I think you can still buy them new from Dorman but I got them from the pick a part yard.
As an aside how did you break a wiper arm? Another Dr Pepper incident? Something like this? rockauto ford f150 wiper armMy 72 W200 has the pretty crappy flat wiper arms with the tiny nub to hold them on. One wiper is already getting loose and floppy I have similar to this rockauto dodge wiper arm No, must have been a 95 F150. That shows the two different styles. Sorry it's been awhile since I got them.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost conversion. 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
