Originally Posted by dvw
IQuote [ Icranked the motor over hole got bigger and oil coming out of it ]
This is not good. If the hole gets bigger its flexing already. If if breaks off and the lifter falls into the cam what will it cost to fix?
Doug
$700.00 to fix it
Make a bar going across the valley
weld it up and put a bushing in it
Just hope if I get an other block that I don't need to do this again
1.39 9.85 - 137 mph
