Hello
I put together a B-1 combo and is using a stock 440 block
Just as I was going to drop the distributer in I found a crack on the front lifer bore
A machine shop told me they can fix it by putting a bar across the lifter valley and have it welded up
I have about $1.500 worth of machine work into this block
1975 440 block half fill, billet main caps , cam is 800/284 at @50
Seems this is a lot of side load and it cracked across the bore
Anyone do anything like this to a stock block
1.39 9.85 - 137 mph
