Have you seen this with your own eyes?
The only way this is possible is to have the battery charged in the opposite polarity. Before you say it can't be done, rest assured that it can. ( a lead-acid battery has to be drained to absolutely nothing and then the polarity can be reversed ).
If he has done this, it is a clever trick for attention. BUT..... it carries huge consequences if someone puts a different battery in the car. ( it will let the smoke escape from everything ). Paul
