I did what Dr. Diff recommended. You use the factory lines for the drum brake car and use the one piece proportioning valve he sells, I inch bore master depending on how you want the pedal to feel. I also changed the rear wheel cylinders to I believe 7/8" (don't quote me). You wont need a rear line adjuster plumbed in. The system is well balanced, and is factory.
