I don't know that I agree with the above recommendations. For what would normally be considered a truck cam then yes 100% agree, but an off road sand dune racer or mud racer you will be spinning the engine a lot higher. Low RPM torque is not in your best interest here. Now rock climbing, pulling a trailer or general dirt trail driving is a different story. With all the gear available in a 4WD vehicle the extra RPMs are very useable. As for the converter I know a stock 11" converter from a HP BB car works fine with the MP 284 cam.
I have a Comp Nostalgia Plus cam in my Power Wagon with a 360 right now and love it but it is a 4 speed and has 4.10 gears.
"Come get your wife"
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Front and rear disc and hydroboost conversion.
2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
