I use strong heat when nothing else works. Since you are going to heat them, try this first. Heat them enough so that they start to smoke, something other than burning off road debris. When hot enough, melt wax from the top down, crayon works. The wax runs down the threads and allows for the break. Works 90% of the time. If not, you are close to half way there with the heating.
