I found this informatiom usefull as I run the long discontinued # 31390 Milodon rear sump A body oil pan that has the crossover tube for the tie rod to pass through. These used a rear drop down ( straight down ) oil pickup that attatches to the bottom of the oil pump. It also used a deep rotor kit that is no longer available!!!
It has been frustrating constantly searching for parts to keep it all going.
I like the looks of the Kevko pickups and wonder if they will work with my pan?
If any of you members have the deep rotor kit or the pan I use I am willing to buy....
Grant Eaton
