Originally Posted by ZIPPY
I've had the best luck using water. Get it idling, warm it up, and spray any suspect areas.
The idle slows down when it sucks in even a small amount of water.
HMM Good idea up I'll try it next time. Part of the issue with brake / carb clean is its flammability on a hot motor. In addition when it evaporates it richens the surrounding air which can lead to one chasing their tail twocents beer
