Originally Posted by polyspheric
3/8" Bundyweld brake line with compression fittings and very short pieces of braided line where needed for small bends.
Using 3,000 psi stainle$$ braid for a cooler line is a bit overkill....
That will work IF the steel line is properly flared and/or adapted to AN or SAE and the hose installed using the correct threaded fittings. Hose clamps on braided hose is a mess looking for a place to happen.
I'm OK with overkill if it means I don't have to worry about it failing.
If the results don't match the theory, change the theory.
