Trying to get my project fired up and driveable for summer. I'm real close , if I leave the battery in the nose. I was originally going to relocate it, but that is a lot of optional work to disconnect switches, auxiliary wiring, alternator wiring, etc. So I've decided to leave it in the engine bay. However, I've added a steering reservoir and cooler set up where the batter WAS because, well, it wasn't going to be there. However, if I use a small sized glass mat battery, I may be able to fit it back in its original location.
So what recommendations are out there for smallish automotive batteries. I'm talking about something in the range of 7" long, 5" wide, 6" tall, for a street going vehicle with an 11:1 small block.
