You could go to D1TV or DragracerTV on YT and watch past Divisional races. Stock qualifying would be best Live timing is displayed on the screen for each run along with car info. Plus video obviously.
Stockers would be cars that aren't highly modified and have been thrashed on to go as fast as possible under the rules. Not unusual for the fast guys to lift at 1000'. D3 has a lot of Mopars if that matters.
Thanks again. Yes, need to be Mopars as I want to use the baseline car (factored HP vs. weight).
