Originally Posted by Sniper
Originally Posted by 383man
All the combination valve is for is to push a piston over to turn the brake lite on to warn the driver if one side looses fluid/pressure
No, that is not all the combination valve does.
The valve that lights up the warning light also closes off the leaky half of the system keeping a firmer pedal than otherwise.
The combination valve also provides metering, proportioning and functions as a splitter.
I'm pretty sure if none of that was needed then none of the factory engineers wouldn't have put it in there, notice how they all did it.
I think I'll listen to the engineers.
If you read the rest of my post you would see it says all later valves had the prop valve and metering valve in them but the early ones did not. And that pistons does not block fluid from the other side. It is two independent systems. Look at the inside of a dual M/C and you can see they are independent of each other. Yea you will lose half the pedal if one side springs a leak but if you look at the inside of the M/C you can see M/C piston will compress the spring in it on one side and still have the other side with a much lower pedal. I did open a brake line on my car and I still have half my brakes. In fact I had both of my rear bleeders open and pumped my pedal and still have just under a half pedal and front brakes that stopped the car but not as good as all four of course. Ron
