I agree, but for another reason.
The pushrod's upper end is moving in 2 planes (up & down for the cam lobe, plus in & out for the rocker arm sweep), therefore higher inertia.
The pushrod's lower end only sees 1 plane of movement, so it gets the heavy end.
Very small difference? Yes, but do it anyway.
Boffin Emeritus
