The 17059 is a Marine gasket.... has stainless steel internal solid core... and a wrap-around (folded) stainless steel combustion armor. Its actually a very durable head gasket for performance usage. NOTE: Stainless steel will not rust (marine environment, includes salt water).
The 1009 and 1039 are true racing intended gaskets -- they have a tin-plate internal solid core... but with stainless steel folded cylinder armors WITH an internal pre-flattened wire ring (racing intended!)... that creates a solid fire wall against detonation/pre-ignition hi-compression common problems.
The bore diameters can be a problem, pending how large you go.
Also, "casting holes" are always restricted by the head gaskets -- to control the flow pattern/direction and volume of coolant.
I'm a former Fel-Pro applications engineer... your questions are common.
Mopar Mitch
"Road racers and autocrossers go in deeper and come out harder!"... and rain never stops us from having fun with our cars... in fact, it makes us better drivers!
Check out MOPAR ACTION MAGAZINE, August 2006 issue for feature article and specs on my autocross T/A!
