Originally Posted by Cab_Burge
I don't think I would use that gasket in your motor, to much of a chance of detonation above 12.0 to 1 compression ratio which could take the gasket out between the cylinders and ruin the block and head twocents
Been there and done that once, a long time ago whiney
Look at SCE and some others for a gasket designed for that compression ratio with the correct bore size up scope
Thanks Cab will do.
Gary
