Originally Posted by W2-408
FWIW I don't even run a second ring at all on my 11.7:1 small block, and have the oil rings crimped down to really low tension. No vacuum pump, just the pan evac system. Going on the 3rd season without touching it and it still makes just as much power as it did when it was fresh, and doesn't use any oil.
Really?
