The trans mount to crossmember bolts and/or mount bracket should be slotted. None of that changes from a V6 to a V8. Did you use the V6 or V8 engine mounts? The 94 may not be the same as the 97. In other words you may need 94 V8 mounts.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
