Originally Posted by BigBlockGTS
I also have a 68 dart with stock front and Dana rear. Big Block / 727. The car was impossible to roll with the trans in it. Once I removed that, the car rolled free. I am sure it is a non-rollerized set up in the trans. Is this common? Might be your problem as well.
I can easily push my car in the staging lanes by myself with a non rollerized 727 in neutral.
With a spool, though, it is exceedingly difficult to go around corners!
'63 Dodge 330
11.19 @ 121 mph
Pump gas, n/a, through the mufflers on street tires with 3.54's. 3,600 lbs.
10.01 @ 133mph with a 250 shot of nitrous an a splash of race gas. 1.36 60 ft. 3,700 lbs.
