You want it as thick as possible, many of the Mega blocks have failed, cracked, at 4.500 whiney
As far as cylinder wall thickness if it is less than .160 finished on either thrust side I won't use them for a serious N/A race motor twocents
I would love to have one that is .250 or thicker up
Maybe my Koleno block will do that at 4.560 luck
