Originally Posted by Sammy
Originally Posted by CMcAllister
I use an old cap. Hole in the top of the cap, large enough to see what you're looking at. Look in the hole with the timing light, engine on. Rotor tab should be at the leading edge of the terminal in the cap. Move the distributor to fix the phasing. Move the crank trigger pick up to fix the timing.
Which leading edge? Towards #8 or #2 edge on the #1 plug. I always forget. Old age.
Don't worry about leading or trailing edges. Just line everything up point to point and then fire it up and check it. That way you'll know what you are looking at. Once you know what you are looking at you can tweak it.
