Originally Posted by sixpacksteve
OK, just recieved the gasket and longer tube set from FHO.
cometic gaskets and quality tubes.
Only problem spark plug wires are Now too short!
i guess i'll need a straight boot!
any recomendations?
I'm assuming your referring to the distributor wire ends, correct?
If so they will make the plug wire end even shorter, don't do that tsk
if your saying on the plug end all the early and 426 Hemi plug wires only have straight ends on them to fit into the plug and wire insulators shruggy
Don't we love our Hemiroid motors whistling grin
