Originally Posted by lewtot184
when i'm comparing heat range between different plugs I measure how far down the porcelain goes in the body of the plug before it bottoms out. the shallower the colder; the deeper the hotter. I always prefer the tip as far in the chamber as possible without any interference with the piston or valves. I always measure ohms resistance.
Good info , thanks.. measure ohms from the plug tip to the electrode?
1966 Satellie.. 12.55 @107.75. 906 heads. 3780 lbs.
