It's really easy to cut or fold the outer lip seal on the piston of the front clutch drum. The rear drum goes together much easier. Have you pulled the piston out? Also check to be sure the inner lip seal protrudes from around the hub. Of course any wear where the seal rings ride in the drums or support would also be an area I would look at closely. The 904 should more than stand up to that HP and weight.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost conversion. 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
