I’m diving into my first 904 rebuild and have hit a problem. I have the case completely stripped except for the low/reverse drum and output shaft. I pulled the pump and all input shaft pieces. Rear planetary is out. Band and the bracket is out. There was a decent size snap ring inside the low drum, on the inside part of the output support. I removed that snap ring and thought the drum should have just slid off the rear support and out, but it won’t. It will rotate one direction and move in/out about 1/8”, enough to cover the snap ring grove, but not come out.
This is a 4x4 Jeep 904/30rh. The tail housing, governer, and parking pawl are off. As it sits the output shaft will not rotate or pull out the back of the case. I assume it should rotate and everything I’ve seen makes me believe the shaft could just pull out.
Thanks in advance.
