There is only ONE force at work in the intake system: pressure differential. Flow of any substance (solid, liquid, gas, plasma) goes from high pressure to low pressure without exception. How it gets there varies quite a bit, but that's all there is. All of those rotating and reciprocating bits do is connect and/or regulate 2 volumes with different pressures.
