Originally Posted by furious70
I'm hoping to do a test fit in my coronet the end of the month, I bought from bouchillon performance. I did have to grind the block on the dr's side a little
I got my engine in this weekend. I had to grind on the ear of the mount to fit the K member and the nobbies that fit in the mount pads were tight, but eventually got the engine to sit down in them. 727 hooked to it and the cross member bolted all in just fine as well.
70 Sport Fury
68 Charger
69 Coronet
72 RR
