In a roadside emergency, I glued a rear corner with bolt hole back on with the fast dry JB Weld. It held for thousands of miles and several months until the cover was replaced because of it. I believe it would still be fine to this day.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
