Check out the other sensors on that common 5 volt feed if memory serves me correct the oil pressure sensor shares the feed. If one of the other sensors pulls the 5 volt low it may trigger the fault. Fixed this fault on an early 5.7 by replacing the oil pressure sensor which was shorted.
Doug
