Anybody ever drill a small oiling hole through the saddle and bearing on the thrust to keep wear down on a heavy clutch equipped combo? Thinking of doing this, as I’ve read about thrust problems with early hemi/ clutch combos. This particular engine has (more) modern 340 main bearings.
All thoughts and opinions appreciated.
"use it 'till it breaks, replace as needed"
