I used a little dawn dish soap and a scrub brush/tooth brush, clean it agitating in all directions, bubbles will likely change in color with agitation. Rinse off, repeat. When you think you have it perfectly clean, do it one last time, bubbles should stay white (no dirt or grease), rinse thoroughly. Use SEM adhesion promoter following directions, then apply SEM color of choice. Works great
