I don't; know if anyone has flowed a set of the rpm heads after cnc porting and with 2.19 valves. I assume your heads still have the stock intake port and not the max wedge ports. I run a set of edelbrock heads from when the first came out and were the only game in town. it would be good to know if you gain anything by going to the larger valves.
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
