We are doing a disc brake conversion on this car. The plan is to put steelies on it with poverty caps. The car has SS springs. I would like to put a 15x8 inch wheel, 4.5 backspace, on the rear.It seems that a 275.60 15 tire should fit fine. I have a set of 15x6.5" steelies that I would like to use on the front.
What tire size do you guys recommend for the front and do you guys have any pictures of your combinations?
1972 Cuda 340 4 speed, 2001 Ram CTD 4x4 6 speed, 1970 Duster 408 4 speed, 1996 Ram 5.9 2x4 auto, 1965 Coronet 500
