1970 Duster tire sizing
#2731652
01/10/20 09:10 AM
01/10/20 09:10 AM
Posts: 1,487 STL
cdstl
STL
We are doing a disc brake conversion on this car. The plan is to put steelies on it with poverty caps. The car has SS springs. I would like to put a 15x8 inch wheel, 4.5 backspace, on the rear.It seems that a 275.60 15 tire should fit fine. I have a set of 15x6.5" steelies that I would like to use on the front.
What tire size do you guys recommend for the front and do you guys have any pictures of your combinations?
1972 Cuda 340 4 speed, 2001 Ram CTD 4x4 6 speed, 1970 Duster 408 4 speed, 1996 Ram 5.9 2x4 auto, 1965 Coronet 500
Re: 1970 Duster tire sizing
[Re: cdstl]
#2731676
01/10/20 10:45 AM
01/10/20 10:45 AM
Posts: 466 Keminmaa
ArcticCuda
Keminmaa
Front; 5.6x15" Rear; 13.5x29x15"
1970 Plymouth GTX 440-6 1970 Plymouth PPR Cuda 489-4 1971 Plymouth Duster Bad Romance 408-W2-8bbl
[Re: cdstl]
#2731684
01/10/20 10:57 AM
01/10/20 10:57 AM
Posts: 1,487 STL
cdstl
STL
Here's what I would like to do...
Front
235.60 15 on 6.5x15" wheel, 4.5" backspace
Rear
275.60 15 on 8x15" wheel, 4.5" backspace
I'm fairly certain that the rear will fit fine, will the 235.60 have any rubbing problems up front?
[Re: cdstl]
#2731725
01/10/20 12:31 PM
01/10/20 12:31 PM
Posts: 19,562 north of coder
moparx
my one buddy used a 205-60-15 on a 7" rim with a 4 1/2"bs for a 72 duster with a factory disc conversion. the car is lowered a bit with the torsion bars, and the 205's clear by about 3/8" on the front, lower wheel opening. that size tire fills the opening very well. i don't know if a 70 duster has the same shaped opening or not, and i don't know how much taller a 235 would be.
