Could be a number of things...bottom shock mount, lower control arm pivot shaft, strut rod. If you suspect its oe, it's probably a good idea to go through the entire front end. You could end up finding multiple issues. May find the issue before it turns into something else/ruins something. If you mark the upper control arm adjusters and don't change the end link adjusters, depending on what needs changed you may not need an alignment.
Follow my G3 Hemi Barracuda build on Youtube
https://www.youtube.com/watch?v=XSDAWczXoZw&list=PLTus_wQu8POADHEeJNJp2nr4NMHEyB9EK
2015 Tri-State Stock Super Stock Champion
2017 Monster Mopar Pro Winner
2018 Monster Mopar No Box Winner
