When you get to the idle mixture screws, if they are frozen be patient. You may have to use heat with a penetrating oil on and off for a couple days. Because the alternative is drilling them out and can be tedious, especially the first couple times. The above post is correct in that the screw in the middle only trims air, and is good for maybe a full point AFR.
Woodruff Carburetor Specialties
330-799-9479
