I'm rebuilding my '68 AVS with the single air bleed adjuster and the two lead-plugged mixture screws. Should I remove the lead plugs or not? Engine is stock, but I live in California, so the gas is crummy. Thoughts?
'67 is an abbreviation of 1967 67' is an abbreviation of 67 feet They are not interchangeable.
