Thanks Doug
Would clean and dry mean soaked in solvent or lacquer thinner to get the oil out and blow dry?
Not sure I’m following re the measurements. Do you mean measure the width of the wheels to see if something is mushrooming ?
Or just check the clearance between the roller and lifter body?
