If the fender tag is still on the car it will tell you what the factory engine and trans were. If the fender tag is gone then I think you're out of luck unless you can find a VIN registry somewhere.
On that year model car you can contact Chrysler Historical and they will send you a copy of the IBM card for the car. And if they have enough time they will decode it for you. But you can do that yourself I believe.
